Can someone tell me, what I am doing wrong, but mails do not work. I guess it has something to with the URL in fact the name is profeta.digital
So the Thanks-Page is well installed under danke.php
But when I send mails it says always «File not found» and mails will not be forwarded.
Can someone give me a hint?
Thanks in advance.
Gene
You might check this out -> https://sparkleapp.com/docs/forms.html
It may be server-related; it’s them, not you.
Just last week, I ran into this when I created a mail form for a client.
The form would not work on her web host…so I tried uploading it to another one and bingo…it worked there.
So…chances are, it’s got something to do with the server’s version of PHP that is / isn’t compatible.
In case you want to try another server, the one that’s working for me is FastComet.com . They offer a very affordable 3 year hosting package for just $106 with a free domain name.
If you’d like to test out your form on my site, you can email it and the thank you.php page with it to me: macmancape@gmail.com. -Dave
Hello Gene
I checked your website: http://profeta.digital/kontakt.html
There are 2 buttons (called SENDEN) on your website with the contact form. I’m not sure, but that could be the problem. There should be only 1 button to send the form. 2 buttons could cause a conflict. They are both linked to danke.php
Added screenshot:
How do I make that form???
Please go on YouTube and search for Sparkle and watch the videos how to do a website with Sparkle, also explains how to to do a form.
FOLLOW UP…When I saw his Sparkle doc, I noticed that he had checked the DO NOT PUBLISH box on the Kontact form page.
Once he unchecked it, all was well.
A good lesson for all users to keep in mind
