Menu for a specific page
Hi. Is there a simple way to create a menu that just lists and enables quick user access to the headings on a specific page?
I think I can do this with text using the On Click function after setting up anchors, but is there are simpler way?
Thank you for any hints.
Hi @Rainey, and welcome onboard! :slight_smile:
You can have more than one Sitely Menu on a page so you can set this to have anchor points. You can also do this with placed Buttons.
Thank you for your help. I worked out how to make a menu that doesn’t just feature all the pages on the website, and I discovered that the information on anchors I was searching for was actually under Scroll Locations. Different terminology!
Learning is fun!
