Minimum page height?
I don’t know what I did, but now every page on my site seems to have a minimum height, and I can’t drag the bottom up any higher, even if I delete all the text on the page. It’s like it hits an invisible wall.
This is making some of my shorter documents have a LOT of white space between the end of the text and the bottom of the page. Is there a way to fix this?
(I’ve checked for hidden elements and there aren’t any in the way)
@Gary there must be something on your page stopping you from shortening your page. Could it be a Popup that you have introduced? Something you have introduced on mobile that on desktop has positioned itself far down the page?
For me I always make sure I either Group or Layout Block my footer and then in the Arrange tab I tick Move With Page Bottom.
