I have an “Object Selection” element which has a list of all 50 US States. For example, object=Hawaii and value=HI. I have these values in a text file, but I can’t figure out how to import both the object and value into the list. What is the format (if any) that works? Is there a way to export the current list?
It seems like it is doable @simkane…
Have you checked out Sitely’s online documentation? - Forms | Sitely Documentation
It talks about how you can import a plain text file!
Unfortunately this Option does not import a value assigned with the object.
Or there is a secret code how to do this.
Maybe our Master Duncan ca say how it is done.
Mr. F
The value is only numeric at this time
