Old style Numbers
I was wondering if the new Sitely version will allow the use of ‘old style numbers’ if the font used contains them?
Hi @cdw, are you referring to this?
If so, then yes, the current version of Sitely does support it :blush: The font used in the example is Georgia.
Spot on Allan, that’s exactly what I was looking for… so how the hell do you acess them?
If you have the latest version of Sitely, you just need to choose a compatible font, like Georgia in my example :blush:
