Page with popups loading slowly
Hello,
I am working on a daily journal and do not want to use the blog.
Now I have a problem with the speed in Sparkle when I create popups (about 30 per page). Every time I open the page with 30 small photos and the corresponding popups, I get the spinning wheel on my iMac (32 RAM, Mac OS Big Sur, Sparkle 3). This is very annoying. It takes too long for the page to load.
Could it be that I have ‘too many’ popups on one page? I am grateful for any help. Thank you.
Link to website.
photography.henriekestrecker.com
The website is loading normally.
Please check on PC. It looks so much nicer.
If you’re using Sparkle 3 then as a first step I’d suggest updating to the latest Sitely. Over time we have fixed interface and performance issues, and we don’t really have the ability to troubleshoot or fix an old version.
If the problem persists in the latest Sitely please send us the project file using swisstransfer.com to feedback@sitely.app
Hi mynona,
good news and bad news.
Good news: your site opens on my side instantly and looks nice on PC.
Bad news: something wrong with your internet connection, your browser cache etc.
Thank you so much, Duncan.
I’m sorry, I didn’t express myself correctly. Sitely was actually updated to 5.6.3 but my license is still 3.x
I just checked and will send you a file as you suggested. Thank you very much for your effort of checking the file. Your kindness means a lot to me.
I work privately on my websites and therefore do not have upgraded to Sitely Pro 5 yet. I keep the design simple and actually do not need all features. Would you still recommend that I switch to Sitely Pro 5?
Best regards
Henrieke
Hello zbr,
Thank you for checking.
Kind of misunderstanding.
As I mentioned yesterday, my browser works fine and the site loads perfectly.
It is the sitely-file that seems very slow to me. (spinning wheel on my iMac)
The performance issue is only about software version, not about license level. You are of course free to use the license level you want.
Thank you, Duncan.
I just checked the file size of the document. The sitely file is huge! 1.5 GB!!!
I have a suspicion now, but I don’t know if I’m right. I thought I’d make my life easier and just drag the photos into sitely as TIFF, thinking that sitely would then reduce the files.
If that’s not the case (automatically reducing the file size and converting it), I obviously need to convert all the files to jpgs or png, right?
There are “only 30 photos” on one page, with the associated popups. The file can’t be that big, can it?
P.S. I just checked the file on the server (FTP account), it is 29 MB.
Sitely reduces the files for publishing purposes, but stores the original.
That’s probably also the reason for the performance issues by the way. The TIFF needs to be converted to jpeg or png even for displaying in the canvas.
Thank you so much! I am grateful to you.
Well, then … back to field 1. I’m sorry to have bothered you with this. I could have known better.
Sometimes the supposedly quicker way is the slower way.
Always something to learn, even in my old age.
Well arguably Sitely should work smoothly with files of any size, or at least offer to convert them to a high resolution but high performance format such as jpeg or png. I think the same problem would happen with a large multilayer PSD or camera raw file. Food for thought, and thanks for raising the issue.
Thank you for your feedback.
Converted all TIFF files to JPEG. Sitely file reduction from 1.5GB to 189.3MB!
Now the file opens so smoothly and shows all images in an instant.
Hi Mynoma, I just visited your website and there is no problem loading it. It looks great.
Hola Gerson. Muchas gracias.
Yes, there is no problem loading the pages. I also changed the structure. Went back to the blog that comes with “Sparkle/Sitely”.
I sat wondering while your splash page loaded what do I need to click?, what do I need to do?, am I waiting for something?, has the page finished loading?, or is there more?
Interesting question. You can’t get access to the blog? Are we talking about this website?
https://photography.henriekestrecker.com/
In fact, I wonder the same thing… A call to action button is not a bad idea, although the surprise effect also works among artists.
Yes that’s the page.
Once I figured out what to do I did get to your blog.
Maybe have a Button covering your image so when I mouse over it it indicates it is clickable by maybe an opacity change?
Okay. Okay …
Thank you for your suggestion! Much appreciated. The whole page is covered by an image and this is clickable. Also the title is clickable. I checked on iPad, on iMac and MacBook. On all these devices it is working. One click and you get to the blog.
BUT I just checked the smartphone. It does not work on iPhone. Now I understand. I guess you were using smartphones. It seems those smartphones with KI and tralala aren’t that “smart”.
I changed it for the smartphone. Now it must work.
Thank you. I think it is common that “mouse over” means you can click the image which leads to another page or picture.
I am an artist. I do not have to challenge people with “surprise effects”. For a long time I think the more simple, the better. I do not like blinking buttons or flashing pages. I prefer simple and modest design. Just some quiet in a world that shouts.
Hi there @mynona,
I totally agree and love the simplicity and minimalism of your site. Also love the art of your photography!
Thomas
