Pages Panel Dropdown Location
On the Pages panel (Left most sidebar of Pages/Layers), is it possible to rearrange the delete and dropdown icons? Too often, I click the dropdown arrow but hit the delete section icon.
It seems more consistent to have the dropdown arrow to the left, as in the Layers, and it would remove the buttons jumping as the dropdown appears, while also prevent my undiscriminating mouse clicks from deleting sections. :slight_smile:
Is this under Sitely’s control?
I will second this, many times I have nearly deleted instead of drop down. It icons are very small and close together.
Or maybe the delete icon should be in red to further differentiate it from the dropdown? Maybe to prevent accidental delete there could be an intermediate tooltip “do you want to delete…?”
That part definitely needs some improvement.
I Agree. Too small and
easy to click the wrong icon!
I agree the buttons need to be highly visible to make it very difficult to delete a section by mistake. The undo function is great but better to prevent than to undo.
Also, the buttons are Mystery Meat. They only appear when you hover over them. Any button must be visible.
I also think the arrow should go on the left.
