PHP vulnerability and Sitely
Two pretty serious vulnerabilities have been found in PHP, diclosed between yesterday and today.
The issue has already been fixed, and the problem is how fast your web host will update their PHP installation. All the version 8 releases of PHP are patched to fix the vulnerabilities.
Sitely use PHP for some features, but even if it didn’t, PHP is generally added to websites automatically by web hosts, and can be sufficient to be vulnerable.
This is a big enough problem that your web host will certainly update very quickly, so I wouldn’t fret over it. You don’t need to do anything in Sitely, once the web hosts updates the server, you’re fine.
What I would suggest doing, if your web host control panel allows for it, is setting your website’s PHP version to 8.x. There will be no fix for PHP 7.x, and Sitely works fine with both PHP 7 and PHP 8, so setting your website to use PHP 8.x ensures that as soon as your web host updates their PHP installation, your website gets it.
Prompted by the PHP issue I checked and found my web server was using v5.6 I changed to 8.4 but then found the user logins to password protected pages wouldn’t work, returning a server error message (The server encountered an internal error or misconfiguration and was unable to complete your request)
I tried other PHP versions down to 7.0 but got the same result. Reverting back to 5.6 restored logins back to normal. Any ideas on what’s happening and how to fix it?
It’s best if you send us the project file and link to the website so we can check: swisstransfer.com and feedback@sitely.app
On the positive side, this will make your software development a little easier, knowing that your new baseline is now version 8. :grinning_face:
Yeah you’d think that. I bet those that are on 5.x will still stay there.
