Preview not loading
Hi Folks,
Anyone have issues with Preview lately, maybe the last week or so? Publishing works fine, but the preview on my local network has not worked, like it’s struggling to load, and I’ve tried it both on my desktop and mobile. As you know, the preview function is invaluable when making even the most minor changes. I’m missing it!
Thank you in advance for any insight.
But is the preview working locally on your Mac? Sounds like the issue might be with your local network in that case.
Hi,
the preview with my Sparkle works perfectly fine, it might the problem with your local network.
Thank you. The preview is not loading on my Mac. Though everything seems to work otherwise, I’ll look into my network.
This is a very old post but it is what I am experiencing now. Was initially random but now consistent. Very slow to load Preview in Safari, but instantaneous in Firefox. Running macOS Sequoia 5.2 (24C101) Safari Version 18.2 (20620.1.16.11.8). Same issue regardless of project. Anyone experiencing this?
Hello :wave:t2:
I’m not sure if this will solve your issue, but have you tried clearing the cache or restarting Safari?
Yes I can mention that Safari has issues and for me I’m relying more on other browsers to Preview my Sitley websites. I’m not a pro on coding but for me Safari at times has stuff going on with javascript, in what I can make out :man_shrugging:
Yes, both but doesn’t help. Pretty sure it’s a Safari issue though.
The last suggestion I can offer is to check that your macOS version is up to date. It’s possible that Safari has received recent updates that could fix your issue, and the only way to update Safari is by updating macOS.
Thanks… macOS is current. Probably a Safari bug, but I am not on a beta so cannot report it. (Update) Safari Technology Preview does not have this issue. Clearly a current Safari bug.
