Previews won't load in my browsers
All of a sudden my local host web previews will not load in safari or chrome. They some images but I can’t scroll down or click on links. I don’t know what happen. I am beyond frustrated as I have a website update to complete and can’t see it.
Can anyone help?
So I figured out that it became a problem after I made a recent update to Sitely. My files that I haven’t saved since the update I previewing fine, but anything after that won’t load. My file from Nov 18 will load a preview however, I saved a duplicate on Dec 18 and it will not load in preview.
Have you figured out the problem? If not, you might work on a duplicate copy and use File/Revert To and try to find where the issue started?
Thanks for tip about the File/Revert! I was able to go back and find a version before the error occurred with the previews.
