Problem with canonicalization
How can I fix a canonicalization issue?
My website is registered as https://mywebsite.com. Unfortunately, https://www.mywebsite.com does not redirect to https://mywebsite.com.
On my Apache server, I used
#+WebsiteRedirect
RewriteEngine On
RewriteOptions InheritBefore
RewriteCond “%{HTTP_HOST}” “mywebsite.com$”
RewriteCond “%{REQUEST_URI}” “^/http://www.mywebsite.com
RewriteRule “." “http://mywebsite.com” [L,R=301]
RewriteCond “%{HTTP_HOST}” “^mywebsite.com[.]”
RewriteRule ".
” “http://mywebsite.com” [L,R=301]
#-WebsiteRedirect
To redirect.
Unfortunately, it doesn’t work. What did I do wrong?
Thanks,
Yuka
Hello :wave:t2: Try this:
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www\.(mywebsite\.com)$ [NC]
RewriteRule ^(.*)$ https://%1/$1 [L,R=301]
Hi Allan! Thanks a lot. Your solution does improve the situation, but not completely, because subpages are not redirected. For example, I have no problems with https://mywebsite.com and https://www.mywebsite.com redirections, but mywebsite.com - Diese Website steht zum Verkauf! - Informationen zum Thema mywebsite. mywebsite.com - Diese Website steht zum Verkauf! - Informationen zum Thema mywebsite. do not redirect. Can you help a bit more? Thanks a lot
Also https://www.mywebsite.com does not redirect back to https://mywebsite.com, only https://mywebsite.com redirects to https://www.mywebsite.com
Also, no redirection happens for blog pages: mywebsite.com - Diese Website steht zum Verkauf! - Informationen zum Thema mywebsite.
Hello,
Sorry for the delayed response. Were you able to solve your issue?
Not really. Duncan promised to fix the issue with blog index pages canonicalization in the next update. Unfortunately he didn’t say when :frowning:
