Publishing irritation
I’ve just done a fairly major revamp of an existing site and, at Duncan’s suggestion, deleted all files on the server before re-publishing. All looked OK but when I did a tiny correction – two characters – and re-published, nothing was visible, just a blank page. Solution: go back and remove all files from server again and re-publish. Success, but irritating and time consuming to have to do this every time there’s a small change. Any ideas, anyon? Thanks, Tony
This is not the case for just about every Sitely website. So something’s up with your web host. Could you try clearing the browser cache to see if that’s the problem?
Thank you. I’ll try to contact the hosting people but, sadly they’re not as helpful as you,
But does clearing the browser cache change anything?
This happens to me all the time. It’s always nothing other than the cache not refreshing. Sometimes it takes a day to show up/refresh - sometimes just an hour. You can always try a different browser - one that hasn’t been used to load that site.
You could try setting up server side caching like this:
