Reappearing text on every page
I’ve created a a header and a menu. I grouped them together and MAY have grouped the text underneath. That text now appears on every page. I’ve tried ungrouping, grouping and ungrouping and nothing seems to work. Any ideas how to help? Otherwise, tonight i’m cutting and pasting the header on the individual pages. I guess you’d call that a work around–caused by my hiccup;). THANKS!
Hi @nancyp, and welcome onboard! :blush:
You’ve gone down the right path to see if you can reverse the entrapped text block. Have you tried going to the original created menu? If you created it on the home page then click on it and then go to your right hand panel under Settings and untick the “Show On All Pages”.
Then go to your menu and now just select what is your menu, and go back to the right hand panel and tick “Show On All Pages”.
Thanks so much for the welcome and thanks for the suggestion. That ‘show on all pages’ button is dangerous;)). Thanks again!
Nancy
Hi Nancy. The other alternative is to find the group in the layers panel on the left, and drag the text out of the group that way. Hope you have already found a solution anyway!
