Recent Websites Not Showing
Hi
I wonder if anybody is experiencing the issue of none of the recent websites are showing in the start-up of Sitely?
I’m running Sonoma 14.7.1 and I’m aware that certain programmes even like Apples own Logic Pro has a similar issue but Affinity Designer for example doesn’t and I can see my recent files!? so not sure if I may be missing something easy like ticking an option box!
Appreciate any help as frustrating having to keep using ‘Open an Existing File Option’
Thanks
Ian
The system will occasionally clear the list for reasons that are kind of obscure and beyond our control unfortunately. The recent websites list is maintained by the Finder, or some underlying system service. In some cases the system doesn’t recognize Sitely as the generator of those files and clears the list.
Thank you for clarifying that
Hi Duncan, thanks for clearing that up, I’ve come on here, because I’m getting the same issue. All my other programmes are showing recent files. Do you know if there’s a way to fix this?
