I am making a new webpage with copy/paste elements in the new page.
I cannot rename the elements in the Layers menu on the new Page?
When I rename it in the Layers menu it reverts to the “copy” name and I cannot change it?
How can I reedit the name in the Layer menu please!
Have you tried changing the name in the Arrange panel (layer name). If neither method works, try restarting Sitely. If it still doesn’t work, report it as a potential issue.
Wow Thanks!
Closing and reopening solved my problem!
I have discovered it will ONLY save the edited text if you click to the immediate right of the text block you edit (otherwise it will not save the edited text)
also you should not the column to the right in Pages-Layers-:— (whatever you call) does not save the edited text in the Layers menu.
This may be helpful for some people.
