Is it possible to have a form set so that a sender has to at least enter one piece of information on the contact form before being able to submit it? and if so the best way of doing this.
I have had a couple that have just come through blank with no information details.
You can make fields mandatory. For example, click on a text input field, then in the “Style” tab you’ll see an option called Validation: Required. Check this box to make the field mandatory, and if it’s not filled in, the visitor won’t be able to send you a message.
