Scroll location and toggled layout blocks
I’m using scroll locations on many pages and in most cases they work exactly as expected. But in others – specifically pages containing layout blocks that default to hidden but can be toggled open – the page does not scroll to the specified position. It either remains at the top or, if I push the scroll location further down, jumps much further down the page than specified. I’m assuming this has something to do with the fact that the overall page height can vary depending on whether layout blocks are toggled on or off.
Is this expected? More importantly, is there a way to make it work? Unfortunately the scroll location I’m aiming for starts above any of the layout blocks - otherwise I could specify a scroll position in one of them.
It’s expected to work (and does in our testing), so what you are seeing is the result of some other problem. Please send us the project file and we’ll take a look. swisstransfer.com to feedback@sitely.app
