Sitely and Stripe
I have just switched from using PayPal for my store on Sitely to Stripe payment. Everything has been configured and accepted …but when I put in the LIVE API the buttons in the publishable Key buy now buttons do not work…then they said to use the secret API which I did…but still nothing.
HELP
Hello.
Without more details and without a direct link with Sitely, it’s going to be very difficult for us to help you with this kind of issue… Payment APIs are very complex and not something to be taken lightly. I would recommend reaching out to a developer.
Thank…but I think I found out what was wrong. The API’s were correct… but the product ID’s were not.
The merch page of my site is here: MERCH
Hey, GW,
were you able to get Stripe working on your site? If you still are having problems, I dealt with it a while back and I wrote this post to document all of the steps I followed to get it working on my site.
Yes.. Finally…it turned out to be the price ID and adding site to client checkout amount other things…it’s a tad overwhelming toast up…but I finally got there.
Yaayy. Stripe works great. Glad you got it sorted.
Ray
