Sketch Plugin stopped working
With the sketch’s new Athens update I can’t use the sitely plugin. It just exports a screenshot of the artboard which is now turned to frames I think, I didn’t have much time to fiddle with it and look for ways to go around it. I don’t know if we can access to the plug-ins data to change the art boards info match with the new changes. In a quick ai search it was written that they’ve also changed their plug-in api.
Are you guys aware of this situation ? Will there be an update?
Please get in touch over email and send a copy of the project using swisstransfer.com (feedback@sitely.app).
We have plugin updates and they should all be in the proper channels, but Sketch has made significant changes, broken a lot of things, and not documented any of the new things. So maybe your project is hitting an edge case we hadn’t noticed.
We actually found the old plugin had an incorrect update URL feed due to the Sparkle → Sitely transition. We fixed the old update URL so the update should show up now.
Hey Duncan, thank you for the update. Sorry for the late reply, I had to put the websites development to the side, it is working perfectly now.
Hi again, I have sent a mail to the feedback about a new issue I was facing, im not sure if you got it but today I got different result on the console, if you didn’t got the mail I can add the all of this one too and resend it. Thank you.
(Additionally I have tried to move the project folder elsewhere, including external drives but it still crashes, with the part of the report below it crashed while I was idling, waiting for if it would crash. (It was using around 1gb of ram at the crash))
System specs: Hackintosh running on ryzen 5 2600 with rx580 gpu card with 16gb of ram installed if that is relevant. Prior to this update there were no issues and I don’t have any problems with other applications
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff811566b52 __pthread_kill + 10
1 libsystem_pthread.dylib 0x7ff8115a0f85 pthread_kill + 262
2 libsystem_c.dylib 0x7ff8114c1b19 abort + 126
3 libsystem_c.dylib 0x7ff8114c0ddc __assert_rtn + 314
4 Sitely 0x109200fab 0x107a9e000 + 24522667
5 Sitely 0x107db9bba 0x107a9e000 + 3259322
6 Sitely 0x1082ac9b2 0x107a9e000 + 8448434
7 Sitely 0x107e72a5e 0x107a9e000 + 4016734
8 Sitely 0x107b9167e 0x107a9e000 + 996990
9 Sitely 0x107b9c8ea 0x107a9e000 + 1042666
10 Sitely 0x108030077 0x107a9e000 + 5841015
11 Sitely 0x10802d4d5 0x107a9e000 + 5829845
12 Sitely 0x10802c820 0x107a9e000 + 5826592
13 Sitely 0x107fcc44e 0x107a9e000 + 5432398
14 CoreFoundation 0x7ff8116860c9 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
15 CoreFoundation 0x7ff81168606b __CFRunLoopDoSource0 + 157
16 CoreFoundation 0x7ff811685e3e __CFRunLoopDoSources0 + 203
17 CoreFoundation 0x7ff811684a7e __CFRunLoopRun + 960
18 CoreFoundation 0x7ff81168408e CFRunLoopRunSpecific + 550
19 HIToolbox 0x7ff81cd9dec3 RunCurrentEventLoopInMode + 292
20 HIToolbox 0x7ff81cda36e7 ReceiveNextEventCommon + 201
21 HIToolbox 0x7ff81cda3a42 _BlockUntilNextEventMatchingListInModeWithFilter + 66
22 AppKit 0x7ff814f9eb7f _DPSNextEvent + 902
23 AppKit 0x7ff8159d36b4 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1290
24 AppKit 0x7ff814f8fc59 -[NSApplication run] + 610
25 AppKit 0x7ff814f62f96 NSApplicationMain + 823
26 dyld 0x7ff8112132cd start + 1805
Please use Sitely’s built-in crash reporter (the window you get after relaunching it), and enter your email address and information on how to reproduce the issue. That is a lot more helpful.
Sent, meanwhile is there a way for me to downgrade it so I can keep on working?
