Us Web Designers are always stressed hoping our clients are ok with how we guide them and help them out, especially when it comes to ecommerce.
I just want to let Duncan & Daniel know that how Ecwid works with Sparkle is faultless. My client (TNG&T) is just so happy going from a nervous wreck in the beginning to now just showering me with accolades!
She is amazed how her-bottom line has improved since her new Sparkle / Ecwid site has gone up, and the positive feedback she has been getting constantly from her client-base!
This is also the case with our other Sparkle / Ecwid client. She is also totally happy!
And then again Sparkle / Shopify is also a faultless experience!
@Mr_Fozzie, a strange one!
Safari in Responsive Design Mode is not honouring my menu settings for mobile. All works correctly on the physical mobile, not like your screenshots - whew!
Seems like Safari in Responsive Design Mode isn’'t picking up my mobile hover settings?
Yes @Mr_Fozzie, I did change the TNG&T mobile hover to reflect the main navigation, but before that I didn’t see what your screenshot was showing on the physical iPhone.
1- Are you using the Ecwid plugin (payment) or a code Embed option?
2- If you are using Ecwid plugin, how did you constrain the width to not be a full width? and if
you are using the direct embed, how did you add it?
Why I am asking this, I’m using the Ecwid plugin and it is great, but I am facing issues with the full width as it is not showing good.
I have tried the code embed, and it is working good in Microsoft Edge web browser in windows, but in safari (both Mac and iOS) on the landing page is working, but when I go to other page and come back it shows nothing.
Yes I am using the Sparkle Ecwid Product Browser widget, and yes i was also unhappy how it pushed out beyond the website’s fixed width for the fact that it looked like it was my mistake! So in the end I had to resort to a bit of CSS which I used in a Sparkle Embed widget.
I also turned on Code Integration under Settings / Miscellaneous / Code Integration and then with the Ecwid Product Browser selected I went to Arrange / Code Integration and ID(ed) it with “ecwid-store”.
To help you out the CSS I used was the following…
Yes as I mentioned this is what you are calling the Ecwid Product Browser. That is where the #ecwid-store comes from that you are using in the CSS that you Embed into Sparkle.
If you have lots of different product categories in Ecwid, can you have them display on different product type pages in Sparkle? Is there a way to split the categories?
Cheers
Sparkle allows the whole Ecwid Store to work within Sparkle so when viewing catagories Sparkle is displaying the Ecwid generated pages for those categories which in turn displays all the product under the category… and it works faultlessly!
