I have tried opening about an 8-month-old sparkle document, and I get am unable to open dialogue. This has occurred since I upgraded to the most recent version of Sparkle. Is there a fix for this?
Delete the new version and reinstall it. Work for me.
Ricardo’s delete Sparkle and reinstall solution confirmed.
You will need your licence code handy - and the process is different depending on if you purchased Sparkle from the Sparkle store or macOs App Store.
Read more here: https://sparkleapp.com/license-code-recovery.html
Hi @liven2, sorry about that.
We have determined this to be caused by two possible issues:
- apps like CleanMyMac removing localizations from Sparkle
- Sparkle being moved while running
We have fixes for both in 3.0.9 (unreleased), for the time being you can re-download Sparkle and it will work.
Thank you! I have re-downloaded the app and installed and it fixed the issue.
Thank you I was able to re-download from the App store and reinstall and it cleared up the problem!
