Suppress sumarize on Mac
Is there a way to suppress automatic sumarize on Mac?
First of all, hello.
I assume you’re talking about the blog summary? Yes, it’s possible : just click on “Delete summary.”
Thanks, I want to suppress the SYSTEM summarize function on my new Mac.
Ah, you’re talking about the Apple Intelligence summaries in your notifications? To disable them, go to System Settings > Notifications > Notification Summary > Off.
But if you need help with your Mac, I recommend asking on the Apple Community site rather than on the Sitely forum. You can access it here: Official Apple Support Community
On the Safari interface Reader was turned on.
Turning if off made the rest of a document appear.
