Text triggering anchor?
Is there a way to have text in a text box link to an anchor on the page? The only way I know how to do it now is by having a button trigger it. Thanks, and I hope everyone had a happy holiday.
If you haven’t found an answer yet, it should work the same as a button. On Click/Go to Page in This Website then click Page Top and select your anchor.
Thank you so much for the explanation. It worked! This is one of the things I love about the software. Once you know how to use it, there are so many powerful things that it can do that don’t require you to know coding. It is taking me a long time to learn all of it, but it is good to know that in the future making websites will be easier. Thanks again.
