Username and password
Good morning, in version 5.6.3 the way to generate a username and password do not match the screens that appear in the tutorial. Thank you.
Hi Antonio, software updates but which tutorial are you looking at. Can you give us a link to it.
Hi Scout, thi is the url Password Protection | Sitely Documentation
and I have this:
txs for all.
Try this video. Hope it helps.
HI again, i don’t have this screen i have this !!!
Are you using the FREE version of Sitely. If you are, you will have to upgrade as the free version does not include password protection. Hope this helps.
Hi.
To use usernames and individual passwords for them, you first need to set a master password for the project. See also the point 1 above the blue highlighted.
Free? I don’t understand. I paid for my program. Or do I need the Pro version?
Hello @antonio_duet :wave:t2:
As Mr_Fozzie mentioned, Sparkle first asks you to set a project password before displaying the user password settings screen. You can either set a password to secure your project (recommended) or click the “Do not use a password for this project” button. Once this step is completed, you will have access to the user account settings. :blush:
