I’m building a simple site to share what I’m learning about setting up a small home, and right now I’m stuck on bedding. My queen mattress is a fairly firm foam one, and I sleep mostly on my side, so I wake up with a sore shoulder. A pillow-top style pad sounds like the easy fix, but I’m concerned a thick one will let me sink in and make my lower back ache instead.
I rent, so replacing the mattress isn’t realistic. I also run warm and don’t want something that traps heat through the night. The ones I’ve looked at vary a lot in thickness and filling, and I can’t tell how much softness is enough without going too far. Has anyone with a firm mattress found a sweet spot for a pillow-top pad that helps pressure points but still feels supportive?
